I have a pair of jamo s803 bookshelfs for rear surrounds that I need to wall mount.
The brackets don't have any mounting holes at the back. They are also tapered narrow in front and wider at the back.
I see the Vogel's with the clamp but theyr pricey. What other method can I use? Can I drill holes in the back and mount that way? I don't want to damage the speakers
Sent from my SM-N960F using Tapatalk
