Well point advice
JuggyUK
United Kingdom
It turns out my well point has a very high calcium concentration, well that's what it appears to be.
Problem is my sprinklers sometimes spray on my windows and it leaves a terrible residue that is very hard to remove. My front windows are also tinted and using an abrasive sponge to get it off scratches the tint.
Does anyone have any advice? The frames are also epoxy coated and the windows are held in by a rubber gasket
