Any recommendation for a brush that would be suitable for wet cleaning for use on a vacuum RCM?
First thought was to use a paint brush but i suspect that the bristles are not fine enough to reach into the grooves (they would merely glide over). Also i fear it might leave fine hairlines. (carbon fiber brushes cause hairlines).
My feeling is that the best brush would have fine bristles that could reach into the grooves without causing any damage.
Another option would be the conventional felt brush but would the fibers reach into the grooves? The MOFI brush recommended for wet cleaning seems to be felt.
Maybe somebody can help before I start spending money (or cause damage).
