Hey guys i am looking for amplifier modules in the range of about 3W into a 8ohm load, it should have 2 channels and it should be efficient (battery will last longer) and requires a single supply of about 6V, which means bridging is probably needed.
It is for a test production of portable cellphone speakers, because I built some powered by TEA2025 and them seems to work pretty well, but it is very hard to make them in numbers because it is nearly impossible to find heat sinks for these chips
Does anyone of you guys have clue about them? or have a advice on the easiest and cheapest circuit that i can build to accommodate the requirements.
thanks
thanks
