Hello, - I am looking for advice on a topic covered before. Most posts I found are slightly older and wireless streaming seem more popular than ever. Some fresh ideas or devices perhaps? Or old ones - old tricks are the best tricks.
I need to connect a streamer (Ethernet only) to my home WiFi but cannot get a cable to the device.
Distance between the router (Wifi6 100mbps) and device is only 5m - line of sight.
WiFi signal is 100% at the device. [Speedtest shows 100mbps]
Looking for a simple, cost effective Bridge solution I can perhaps plug into a wall socket behind my streamer and connect a short Ethernet cable, allowing me to extract glorious HiRez music from my streamer.
Any comments, experiences shared or advice will be highly appreciated.
Many thanks
Charl
Many thanks
Charl
