Hi guys, yesterday got this connected up and started playing a few tracks. the sad thing is that it sounds really thin. anyone have any great ideas to give it some life?
I am sure a really decent phono stage will help, as the Rogers built in one is most likely a little weak. but i am sure there is something that can improve the TT performance. any ideas?
YAMAHA CS50 P
SPECIFICATIONS
Motor: AC synchronous
Speeds: 33 and 45rpm
Platter: 300mm, 1.2kg
Wow and flutter: 0.08%
Rumble: -60dB
Tonearm: static balance type
Stylus pressure: 0.5 to 3g
Cartridge weight: 5 to 12g
Cartridge: Ortofon F 15 EO
Stylus: 18 x 8um elliptical diamond
Frequency response: 20 to 20,000Hz
Recommended tracking force: 1.5g
Dimensions: 440 x 370 x 160mm
YAMAHA CS50 P
SPECIFICATIONS
Rumble: -60dB
