ZMF Pads for Focal Clear + Amazon Arya Pads
Solid_Tuna
ZA
Great fit, don't sound drastically different. These should last a bit longer than the stock pads do.
I wanted to get the Utopia pads but that would cost around 5k which is nuts.
These are a bit thicker than than the stock and give a nicer sense of space and gives room to compress over time as well.
These are quality, as you would expect from ZMF.
These Arya Pads were from amazon - thought I might as well try for the price of $30 - Apparently sheepskin, unsure.
These actually cause me to turn of my EQ and seems to bring the mids forward quite nicely. extends the bass slightly more, probably the denser memory foam, vs normal foam.
Seem decent and im happy with them.
