Help Needed with new Tv
Anton
Pretoria
Hello All .....
Please if someone can help me it will be much appreciated
I Bought a new 4K Tv that supports HDR and DV
My Older tv did Also do 4K with Hdr ,and i did watch whatever in 4K and Hdr so there was no problem then ....
The issue now is that when i go through my Amp like normal i only see 4K 30Hz on my Media player ,when i connect my Media player straight to my Tv is shows the correct resolutions that i want , so just through the amp i only get 4K 30Hz
My Amp Does support 4K because it also worked on the older tv
My Amp is a Denon X4200w
The Media Player is a Shield Pro 2019 Model i think
I did set the amp not to Upscale anything ,so only pass-through
Thanks
