Room treatment advice
TimbaLand
Fourways
My room is 7.5m long, 4m wide and 3.2m high. I recently removed the 18x 120 x60cm panels I had and replaced them with 8x 300cm x 60cm and a 2 square metre skyline diffuser at the back. No real pre installation room acoustic measurements were taken. I used conventional wisdom on deciding what places to treat. I also have corner bass traps on the 2 fronts corners.
I’m not good with room acoustic measurements and I only rely on auto room eq to do its magic. I ran ARC Genesis (Anthem room eq) and this is what it gave me (the before and after calibration). What’s your thoughts on the before measurements. What can I still do to the room to get a more even response if necessary?
