Which wall mount to recommend for tilting a 15kg 55# tv?
bobbyb
Johannesburg
I'm probably going to buy the 55 inch Hisense M7000 that all the stores are now selling for R12k.
I am going to wall mount it and circumstances mean that the tv has to sit higher than eye level. So it makes sense to buy a good mount that can tilt to the right angle.
All the relevant connections are behind the tv. Some are accessible from the back-side but some are all the way at the back (some HDMI and all the RCA connections)
I don't know anything about wall mounts and the pros and cons. I would like to get something good that doesn't break the bank. What are the opinions of people on the forum?
This is what I have found locally:
R599.00 SANUS - 32"-47" Tilt Bracket BAMVTL
http://uat.dionwired.co.za/default-category/tv-blu-ray-satellite/mounting-brackets/ellies-26-47-tilt-bracket.html
R649.00 ELLIES - 42-74" Wall Mount Bracket With Tilt TILT BAMLFPWMT
http://uat.dionwired.co.za/default-category/tv-blu-ray-satellite/mounting-brackets/ellies-large-wall-mount-bracket-with-tilt.html
R990.00 PHYSIX PHW200M TILT TV BRACKET 32-55″ (MAX WEIGHT 30Kg?s)
https://www.soundxshop.co.za/product/physix-phw200m-tilt-tv-bracket-32-55%E2%80%B3-max-weight-30kgs/
R1,390.00 PHYSIX BY VOGELS PHW-200L TILT WALL MOUNT 37-65"
https://www.stax.co.za/products/physix-by-vogels-phw-200l-tilt-wall-mount-37-65
R1,999.00 SANUS - 47"-70" Full Motion Bracket F180D BAMVFML
http://www.dionwired.co.za/default-category/tv-blu-ray-and-satellite/mounting-brackets/ellies-32-70-full-motion-bracket.html
R 2,735 Ellies Sanus Flat Panel Full Motion 37 To 65 Inch LED Superslim Wall Mount BAMSLEDM65
https://www.takealot.com/ellies-sanus-flat-panel-full-motion-37-to-65-inch-led-superslim/PLID29418545
VOGELS WALL 2250 FORWARD-MOTION TV MOUNT (32″-55″)
https://www.soundxshop.co.za/product/vogels-wall-2250-full-motion-tv-mount-32-55/
